Thread: CYA too high?
    Default Re: CYA too high?
    You'll find that almost none of us on this forum will use test strips for anything but ballparks, because they are considered to be very unreliable. As for your CYA level, I would not trust any level that is obtained by any other way than with chemical reagent testing. If you do indeed have a CYA of 100, then you're going to have a hard time keeping algae out of the pool unless you run a chlorine level of around 10 (minimum) all summer. I do run my CYA at 80 - 90, but I am very consistent with keeping my chlorine levels up. I live in Louisiana and my pool is in full sun all day, so that's the only way I can keep chlorine in the pool. My suggestion is that you drain and refill, at least small amounts, as often as possible to bring the CYA down a bit. I wouldn't even leave mine at 100.
    Lehigh Valley, PA
    Hi Janet,
    I use strips and reagents. The strips for a quick and dirty first thing in the morning, the reagents every other day, but the reagents I have do not test for CYA. The only way I can test for that is with either the strip or at the pool store.
    I have to add water about twice a week, an inch or so each time, because the dogs drag out a lot. We've stimated we loose a gallon each time a dog leaves the pool. That comes to roughly (ruff-ly?) 50 gallons a day lost.
    I also lose some volume when I backwash and rinse, so there's some refilling happening then, but I cannot possibly drain and refill to dilute the CYA level. My well won't take it. If the CYA is truly at 100 then I should be back to 50 by the end of the season
    I will keep an eagle's eye on algae build-up and keep the Cl level up to compensate. Thanks for the heads up on that.
