Results 1 to 10 of 29
Thread: I'm confused
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    Default Re: I'm confused
    3 hours later testing
    temp -76
    FC - 5
    CC- 2
    cya - 55
    TA -280
    CA -0
    ph - 7.2
    I'm adding 3 more gallons of bleach to bring chlorine back up.
    Why is venting needed on tablets? If I can't use the feeder, then I can still crush them and throw in the pool.
    Poolsean,
    I agree, all the cal hypo tablets and capsules I have seen are designed for using in the skimmer or some of them can also be used in a NEW floater that has never held trichlor. IMHO, they work best in the skimmer. They should not be used in a trichlor feeder which is pressurized! It is possible for an explosion to occur.
    Jul 2006
    Wichita, KS
    So, I should use these by dropping them in the skimmer? How many at a time?
    I tried shutting off the pump to let the pool settle overnite and it didn't change it's appearance at all. It did lose virtually all it's chlorine. I had 14ppm FC and 2 CC before, and this morning it's .5 and .5. Nothing else changed. I raised the pool level in the afternoon to the normal level several hours before shutting down and brushed everything. I think I found some additional algae that missed the chlorine shock last week. That's the only thing I can figure that would explain the big loss in FC.
    Jul 2006
    Wichita, KS
    I'm finally making some progress with my pool. I can see the bottom in the 4' section and as of this morning my tests showed
    temp-77
    FC-6.5
    CC-1.5
    ph-7.5-6
    cya -50
    TA-300
    The TA is my next area I'm going to work on. I will start adding the acid and aerating the pool. I found an interesting setup in my inherited box of pool stuff. It has a fitting that plugs into the Polaris jet and turns 90 degrees and is adjustable height before another 90 and ends with a parallel sprayer head. I checked it, and it is perfect for spraying 20 streams of water into the surface of the pool. I can aim the spray 360 degrees so I can have a fountain or straight into the water with maximum force. I remembered seeing it, but had know idea what to use it for until I saw the pictures in the other thread.
    FC 6.5, CC 1.5, CYA 50?
    You need to keep your FC at 15 or it will never clear. I'd worry about that before T/A since it's still cloudy.
    Jul 2006
    Wichita, KS
    I haven't dropped the chlorine those last readings were first thing in the morning after putting the FC at 20ppm last night.
    I put it back up and kept it all day. Is there a reason I can't do both?
    I got some muratic acid and dropped the ph to 7.2 and installed, what turns out to be a rather neat fountain. The TA has come down to 230 just today. While running it looks like this:
    Well, you can, and at 7.0 to 7.2, the chlorine will be more effective at killing algae than at 7.6-7.8, so it will help.
    I just don't want you to lose focus on your primary task--killing the algae. Nor was it clear that the measure was between shocks/before the next scheduled shock.
