Thread: Need help with chemicals
    North Florida
    Default Re: Need help with chemicals
    Hi Mariza,
    Yes, muriatic acid will lower your pH. Approx. 19.2 oz of MA will lower your pH reading by .2 in a 24,000 gallon pool.
    pH adjustment alone, however, won't solve your cloudy water and algae. You need chlorine - - and probably a good amount of it. How much chlorine depends on what you have now (you said you have none) and your stabilizer level (aka: conditioner, CYA, cyanuric acid). I too found all the information on balancing pool water a bit confusing to start, but it gets a whole lot easier!!
    As Carl said, you need a good test kit. I can't emphasize that enough! Without the means to tell what's going on with your water, you'll just be throwing chemicals in the pool, hoping something will magically make it all better. That's a prescription for a disaster while spending a whole lot of money . To clear your water, you'll want to test your water quite a bit. The 5-way or 6-way drops test kit from Wal-Mart could get you started and it's less than $15. In a bind (not as a routine), take a water sample to a local pool store and have them test it for you. If you can post your "exact" pH, chlorine (FC and CC), and stabilizer readings, you can get a lot of really good specific advice that fits YOUR pool. An alkalinity reading (TA) and calcium hardness (CH) reading would be nice too.
    Your pool CAN get clean and clear again - we just need some solid numbers to give you the right advice.
    Sandy
    Ft Lauderdale, Fl
    If you can get a water sample tested and post the results back here, we can assist more. Test for:
    Free Chlorine
    Total Chlorine
    pH
    Total Alkalinity
    Calcium Hardness
    Cyanuric Acid
    After treating your pool for algae, make sure you backwash your filter (or clean your cartridge, whichever the case is). Don't worry about adjusting alkalininty until after algae is cleared up, but definately bring your pH down so that the chlorine can be more effective.
    Another thing, depending on what your cya and pH levels, you can use a tri-chlor shock treatment if cya is low and pH is high. Tri-chlor will somewhat balance that due to the low pH and cya nature of the tab. If Cya is high and pH is high, you can use bleach and muriatic acid (but not at the same time - do not mix these in a container!!!)
    If calcium hardness is high, do not use any calcium hypochlorite based shock treatments.
    So you can see why knowing what the current chemical levels are. From there, we can recommend the correct solution for you.
    Sean Assam
