Thread: Vinyl Liner stain
    Default Vinyl Liner stain
    I have a stain on my vinyl liner at the water line in my above ground pool. The stain is on the part of the pool that faces Southwest. A guy at the pool store told me to scrub it with an abrasive pad they sell at the pool store. I did that on Saturday and tonight I noticed that the finish appears to be scrubbed off below the water line. I didn't know what it was until I looked closely and saw scratches.
    I did not tear the liner, but it is just a little bit rough in a couple of areas where the finish is gone. I hope I didn't do any damage, other than to the looks of the liner.
    I hope someboy can advise me if this will result in the liner failing and if there is anything I can do to repair this.
    Thanks!
    Cool Re: Vinyl Liner stain
    Welcome to the forum!! I'd say that the liner will be fine, it's just the surface and a little ink that came off. Next time you see the line come back, use a paste of bakingsoda on a green kitchen scrubbie/sponge - it will be a lot less abrasive to the liner.
    Again , welcome to the forum! In the future, please ask us first before you listen to some dolt at the pool store
    Default Re: Vinyl Liner stain
    Thanks for the answer. I will be sure to come here first in the future!
  1. Vinyl liner stain
    By shircri in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-13-2008, 09:25 PM
  2. Stain on Vinyl
    By vinnygnj in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2007, 04:31 PM
  3. Oily Deck Stain on vinyl Liner
    By prostitch in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-09-2007, 03:20 PM
  4. Vinyl liner stain, above waterline
    By ckelly in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-29-2006, 11:01 AM
