Thread: FC not holding overnight...
    Front Royal, VA
    Default FC not holding overnight...
    I went through the conversion and everything is crystal clear. I have my CYA at 35 and pH is 7.6. TA is ~180.
    I put in almost 3 gallons of bleach last night and after an hour the reading was over 5. After 3 hours of daylight, I'm back to .5. Now, either I'm losing it a bunch overnight or 3hrs of sunlight is killing it off rather quickly. I'd hoped to get an earlier reading prior to full sun-up, but with CYA, I'd think I'd hold something.
    Using a Taylor K-2005 test kit....
    Default Re: FC not holding overnight...
    Maybe you are still metabolizing something.
    Also, if you add polyquat, the FC will drop over 48 hours.
    Front Royal, VA
    I haven't added any Polyquat, yet.
    I'm going to search on dissipation rates, but is there any other std rate available?
    You may need a little higher CYA to stabilize better. I had no reading on my CYA test, so I went an got a floating feeder w/ a few 3" pucks to get some into the mix. When it gets up to ~50, then I'll start the bleach. The pucks really are easier, they just need to make 'em w/o CYA!!
  1. Loosing too much chlorine overnight
    By douge55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2011, 08:51 AM
  2. Liner slipped overnight! HELP!
    By ConnieStewart in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2010, 06:15 PM
  3. Only a 1ppm loss overnight but still green bits on bottom
    By subedoo in forum Dealing with Algae & Slime
    Last Post: 06-28-2007, 11:03 AM
  4. new water...overnight color change
    By PFPAM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2007, 12:41 PM
  5. Holding chlorine overnight
    By AndieP in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-12-2006, 04:19 PM
