Old Nautilus leaks DE in to the pool.
I have an old Nautilus that has probably seen it's better days but since I'm hard-headed, I'm going to try to keep it going another year or two.
Last year I started getting a little DE in the bottom so since I had a grid or two that were looking worn, I ended up just replacing the entire grid set. When I took it apart, the stand pipe o'ring had been replaced by rolled up duct tape so I assumed that this was at least partially the problem.
I ordered a new o'ring but when I went to re-install it, I can't get the dang'd maniold to seat all the way down over the o'ring on the pipe. Try as I may, lubed and all, can't get it down tight. I even used a mallet to try to beat it on-not a good idea to beat on plastic.
I guess I now know why the duct tape.
Any ideas? I guess I should look for a smaller o'ring but I wouldn't know where to find one.
Thanks.
JB
- You may not post replies
- You may not edit your posts
Forum Rules
