Results 1 to 10 of 31
Thread: Lowering TA with Dry Acid Or Muriatic Acid
Threaded View
  1. #8
    Jul 2006
    Default Re: Lowering TA with Dry Acid Or Muriatic Acid
    So my procedure to lower my TA is
    1) Lower pH to 7.0-7.2. (Muriatic or dry acid are both fine) This lowers T/A somewhat.
    2) Turn on the fountain
    3) Lower pH again to 7.0-7.2, bringing T/A down some more.
    4) Turn on the fountain again
    5) Repeat 1-4 until T/A is in the desired range.
    Is there a formula for how much Muriatic acid, or dry acid to add to reduce the ph? I.e. 1/4 cups of muriatic reduces pH by 0.5, or is it not that simple?
    That's all you need!
    Last edited by CelticDaddio; 06-13-2007 at 11:30 AM. Reason: Added question about muriatic acid formula
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
