Update: I added 1/8 gallon of muriatic acid last night... pointed 3 returns upward and increased water flow to the hot tub waterfall (into the pool) to help aerate. Readings were TA 180/PH 7.4 this at 9 AM.
So added another 1/8... in addition to the waterfall and returns adjusted upward, I turned on the blower in the hot tub, and turned on Polaris cleaner pump (without cleaner attached)... lots of water movement. Readings at 2:30 are TA 140/PH 7.4.
Is this to good to be true? Seems to be happening fairly quickly and with far less than the three gallons the pool store told me I'd need. Should I expect a rebound? What do the experts think? What should I do next?
BK
