Results 1 to 10 of 14
Thread: Where to buy Muriatic Acid
    Jul 2006
    Default Where to buy Muriatic Acid
    Where can I buy Muriatic Acid? What type of store? Is it a cleaning product?
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    De Soto, Missouri, USA.
    Default Re: Where to buy Muriatic Acid
    Lowes,Home Depot, almost any hardware store. I think its used most when cleaning masonry.
    Mike
    Downingtown, PA
    Quote Originally Posted by mlh View Post
    Mike
    I find it in the paint section of most hardware stores-same place you find mineral spirits. Even my neighborhood True Value store carries it in gallon plastic bottles. Usually listed as muriatic acid-hydrochloric acid 32%
    Don
    30,000 gal concrete pool -- Autopilot SWG
    Using BBB for chemistry -- Using LaMotte ColorQ for testing
    NW Oregon
    I found mine at Costco last year. 2 gals in a box but I don't remember the price. I get my bleach there too, 2 - 1.4 gals for 5 bucks.
    34 X 22/15 inground vinyl w/ Hayward equipment
    Jul 2006
    How do you like the ColorQ? Is it worth picking one up? Accurate?
    Ed
    Quote Originally Posted by donaldm823 View Post
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    mas985's Avatar
    Pleasanton, CA
    Be careful when buying acid. Home Depot near me has recently moved to 14% acid instead of 29% they use to have but did not change the price. This could be just a California thing.
    Mark
    Jul 2006
    My wife went to Home Depot today so I asked her to pick up some Muriatic Acid.... She got a little concerned when she saw "Caustic Substance" on the label and found out that it is a controlled substance and could only by one box. I had no idea it was a controlled substance... Why is it controlled?
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    You might try your local Ace Hardware store. Last year we bought it 4 gallons to the case for about 2 bucks a gallon.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    MikeInMo is offline ** No working email address ** MikeInMo 0
    Oct 2004
    I am getting robbed by my True Value guy...$5.50 a gallon.
    Guelph, ON, Canada.
    I live in Canada, and also had problems finding it in the more popular hardware stores, Home Depot didn't even carry it.
    I found it at the TSC hardware stores.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
  1. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  2. How much Muriatic Acid?
    By mccato in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2006, 09:21 AM
  3. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  4. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
  5. How much muriatic acid to add?
    By Blemished_Chemist in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 09:15 AM
