Thread: How to adjust CYA down
    Default How to adjust CYA down
    From a post I made earlier a comment was made about my CYA being high, currently it is 151.
    I realize I need to keep a high ppm of chlorine in the pool to keep it free of algae, but I am concerned about what this will do to one of my children's sensitive skin.
    My question, is partial draining and refilling the only way to lower the CYA? or is there another way? We are in a drought at the moment and the city is imposing a 200% water fine if you use more than your alloted amount in a month.
    Thanks in advance
    Default Re: How to adjust CYA down
    Only way is to drain partially and refill
    Any idea how much we are talking about? 15,000 gallon above ground. 10%, 25%, 50%
    Thx
    There is another way. You don't want to know it.
    But trust me, draining and refilling is FAR easier and cleaner, not to mention faster.
  1. How to Adjust pH and TA
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2007, 05:22 PM
  2. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 07:33 PM
  3. Adjust TA first, right?
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2006, 11:07 AM
  4. Which one should I adjust first
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 01:32 PM
  5. Should I adjust anything ?
    By aswetich in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-02-2006, 09:34 PM
