Re: Pool Rover Plus Help!
psciotti
Just purchased the Rover Plus from Costco and used in pool last night (16' x 28' - 3-6 deep - vinyl liner). It completely missed one section in low end and one section in deep end. The owners manual is very generic and apparently the only setting I have to worry about is the dial (played with that thru cycle) on the transformer. The front wheels of the unit have this removable "pin" that makes one wheel fairly stationary - the other wheel slides back and forth 3" or so. Should that pin be out so both wheels slide back and forth? Should both wheels be pinned so the unit now has 4 stationary wheels?
Thanks for your help ~ Paul
No! The pin needs to be in 1 side or the other so it makes K-turns. Alternate the pin after every use. There are 2 basic adjustment to this cleaner. The timer adjustment (the dial how often it turns around) and where you drop the cleaner in (long edge of the pool in the middle generally). Try different variations of both and until you find the setting that works best. I would also not be too concerned about small spots it misses (did it miss an area the size of a sheet of newspaper or a king sized bed?), just brush the dirt towards the middle. No cleaner save the remote controlled ones can provide 100% coverage.
26,000 Vynil Liner L Inground
Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
Poolvergnuegen thepoolcleaner Pressure Side Cleaner
Loop-Loc Mesh cover
