Pool epoxy, from the inside. It sets up underwater, and the pressure from the inside will help it seal.
Or get a plastic welder and weld it with multiple layers.
jb weld! i used some on the side of the autopilot manifold i burnt through with a soldering iron (long story) and used jb weld..no water leaks, stands up to the pressure, stuck fine to the pvc.
Thanks guys...I may give JB Weld a try on the outside of the tank. I really don't want to mess with going inside the tank. I'll sand it good and give it a try.
Thanks for the reply........Jay
18 x 36 vinyl 23,000 gal. Located Burlington, NC
Just out of curiousity... what kind of tank is this?
I have a small hole (crack) on the inside of my old filter but I may patch it and hold onto the tank.
Let me know how the repair turns out.
Thanks.
I was up late the other night watching TV.
Why would anyone use anything else but
Leak Ender 2000 !!
<Just kidding folks! Don't waste your money!>
40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
Been using BBB for over a year! Excellent results!
