Results 1 to 8 of 8
Thread: DE in sand filter
    Tennessee.
    Default DE in sand filter
    I have read,.. with much interest.. the "DE in sand filter" idea. I want to try this method in my sand filter.
    Where do I buy DE?
    What do I ask for?
    Did someone say it is available at LOWE'S or HOME DEPOT? (What dept?)
    I have tried to read as many posts as I can find.. but I am still not clear on the answers to these questions.
    Thanks for your help.
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    mikemedic is offline ** No working email address ** Thread Analyst mikemedic 0
    West Virginia
    Default Re: DE in sand filter
    Lowes, Home depot, Walmart etc
    DE=Diatomaceous earth
    In sand filter you backwash your sand filter, add very small amounts in the skimmer and watch your PSI, only want to go up 1-2 PSI. More than likely you will only use 1/4-1/2 cup tp accomplish this
    Lowe's keeps it outdoors in the garden section. It takes hours for the DE to settle and the pressure to climb and reach a steady point, so add very small amounts (like a quarter-cup) at a time and then wait before adding more.
    I actually bought mine at KMart for $8.75 @ 25#
    Tennessee.
    OK.. HOME DEPOT had D.E... but it was $20.. same thing at WAL-MART.
    The D.E. I found was called: D.E. Filter Aid, Pure diatomaceous earth. The box says: Recharges D.E. filters, Improves filtering efficiencies. It was by AQUA CHEM and was $20 for a 24 pound package. I didn't buy it.
    Is this what everyone is buying?.. I would like to find the $8.95 bag someone mentioned.
    Jul 2006
    SE Georgia
    Quote Originally Posted by chuck9997 View Post
    That's exactly what I bought. It will last forever!
    Add it slow, watch your filter dP and let it work. There's plenty of posts on this site to tell you how to add it.
    I add it slowly until my filter pressure increases by 2 psig. It takes about 24 ounces, or about 2 plastic solo drinking cups worth, in my sand filter.
    If your pool is cloudy, it will help clean it up in a hurry.
    When you backwash, it will get pushed out of your filter and you will have to re-add. Even still, the 24 pound box will last a lifetime.
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    Thats the exact stuff I got, it just happened to be on sale at KMart. I guess I lucked out!
    Tennessee.
    Ok.. I found the D.E. at K-Mart.. The 24 pound bag was $15.29.. not bad.
    Thanks for everyone's help.
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
