Results 1 to 10 of 17
Thread: Algae - need a primer!
    Mandeville, LA, USA.
    Default Re: Algae - need a primer!
    You need to post your pool chemistry numbers for anyone to advise you on getting rid of the algae. Include free chlorine, combined chlorine, cyanuric acid (CYA), calcium hardness, pH, and total alkalinity. CYA is particularly important.
    It sounds like you have mustard algae which can be pretty tough to get rid of. The treatment is simple. Raise your chlorine to shock level, test the chlorine 3 times a day, and return it to shock level after each test. Repeat this until the free chlorine level holds overnight and the visible algae is gone. Your shock level is a function of your CYA level (see here).
    You can get rid of this algae and keep it away, but it will take diligence and patience.
    heymom1 is offline ** No working email address ** heymom1 0
    Thank you very much. My son was supposed to have been testing the water but I think we let the levels get away from us this week, what with the rain, the heat, and more sunlight. It wasn't as bad as it is today, and I basically never noticed, and thought hubby was seeing things when he told me there were some new stains.
    I will get the water tested tomorrow at the pool supply store, and have son do it with our kit too. Hubby wanted to buy some shock tonight, so we did. I resisted the salesman's pitch for algaecide, though. Do I need the algaecide if I'm already shocking? That stuff is EXPENSIVE!!! We did buy a wire brush and hubby is out there brushing the walls and floor right now. Is that OK & a good thing to do?
    Why is CYA level so important? I know you are not supposed to get that number ultra-high, or you have to drain off water to get rid of it.
    Do you think I will be able to get this at least under control and then be able to leave it for a week?
    Son just told me that CYA level is 100. I"m going to do the test myself to see what is going on. Now, bear in mind we have just added 1.5 lbs. of Zappit. (I know, but hubby wanted to do something right away, and I didn't have enough confidence in the strictly bleach method until I get the info. from you guys.)
    Thanks.
    Also: What does "Vacuum to waste" mean? We have no vacuum mechanism, only a Polaris. I can run the Polaris with a fine mesh bag, but I don't know if that will actually clean out the algae.
    Exclamation Re: Algae - need a primer!
    One more question - We have an ozonator (electric) on this pool. Please advise if that makes a difference in the treatment from here on out. I think it's still working...NOPE! Its little blue light is out. Now what???
    With a CYA level of 100, your shock level is 25 ppm. Shock as I described in my first post until the chlorine stays at the same level overnight. To clear this quickly, it's very important to test often (at least 3 times a day) and keep bringing the pool to shock level after each test.
    Keep brushing; the more the better. If you don't have a manual vacuum, the Polaris may help some.
    Thanks, Kurt! No, we don't have a vacuum. I will test the water first thing in the morning - I see that several things getting out of line allowed the algae to gain a foothold. I'm going to take the water to the supply store of the company that built the pool and put in the ozonator. Other than selling me chlorine, they've been pretty good with advice - not trying to up-sell me like the Warehouse Pool guys always do.
    Do the shock granules also add more CYA to the water? I have the in-line feeder also and the dial up to about 4. I realize that most of y'all do not ue the pucks and maybe after this is fixed, I will have the confidence to go with just the BBB method.
    Is there NO way to lower CYA other than draining the pool? If I don't add any more tri-chlor, will the level eventually drop on its own, what with rain, adding non-chlorinated water, etc.?
    Thanks a lot for your help!
    Quote Originally Posted by heymom1 View Post
    If it's di-chlor, yes. If it's calciun hypochlorite, no.
    Overuse of pucks is what got you here. Why would you be confident in the very thing that caused the problem?
    It will go down on its own through splashout but that will take a long, long time. The good news is that you can live with the high CYA. One you get rid of the algae you'll just need to keep your free chlorine between 8 and 15 ppm.
    Good luck.
