Results 1 to 10 of 34
Thread: pH keeps creeping up
    Default Re: pH keeps creeping up
    Amir,
    I use Firefox on the Mac and the links work fine so this must be something specifically wrong with Firefox on a PC -- very strange.
    Frank,
    Aeration only causes the pH to rise by the outgassing of carbon dioxide. It does not change the TA. When you add acid, then that lowers both pH and TA so the combination of the two is a net result of lowering TA. Carl explains this here and I have a chart about this here.
    Richard
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    I don't know why I said "lower pH" I knew that it didn't do that. DAH!!
    Thanks Richard,
    I checked my pool test log spreadsheet from last year and the year before that and I see where we had a very minimal amount of pH rise last year unless there was rain or "rug rat" activity, but then it seemed to stabilize without acid addition. I will watch it for a while to see where it goes.
    I will be discontinuing the use of the Bleach pump for a couple of weeks while I use some pucks to get the CYA up to 30. Right now it is below the capability of my test equipment but I believe it is around 20 ppm. If the pool is uncovered all day the FC depletion goes to around 3-4 ppm so I think a bit more CYA will be in order.
    Thanks for your thoughts on the pH, after searching and finding a lot of pools getting several pints a day, I do not feel too bad.
    By the way, NO!! I do not add anything surrepticiously that Jakebear is unaware of (See post #8).
    I value my life
    Front Royal, VA
    I also use Firefox 2.0 on Linux and the links display just fine.
    Amir is offline Registered+ Thread Analyst Amir 0
    Potomac, MD, USA.
    I run firfox on PC. I even copy and pasted the link
    http://richardfalk.home.comcast.net/pool/FC.htm
    and got "can not find server"
    I can get to his site
    http://home.comcast.net/~richardfalk...tml--logo.html
    but not to the links with firefox!!
    amir
    Amir,
    Just for the heck of it, I duplicated the FC.htm file and changed the name to FC.html so see if this link is accessible. If it is, then Firefox on the PC requires the extension to be "html" instead if "htm". Let me know.
    Richard
    Dec 2005
    Royal Palm Beach, Fl, US.
    I am running Firefox v2.0.0.2 on a pc and I am able to pull up the pages that only have the .htm extensions.
    Sal
    Potomac, MD, USA.
    Richard,
    yes, the link was accessible. you are right it needs html. I guess 90% of the world uses IE so I am used to finding a way around or going to IE when nothing works.
    Amir
