Results 1 to 10 of 10
Thread: Thinking about a solar cover...
    Ontario.
    Default Re: Thinking about a solar cover...
    Just a solar cover will do very, very, little to increase the temperature of the pool. The best utility of the cover is if you have a heater and the water temperature is heated to be higher than the night time temperature of the air. That results in a large loss of heat due to the evaporation, which is greatly mitigated with the use of a solar cover.
    If you get a cover without any other heating, I will virtually guarantee that after a bit you will hardly use the cover.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Upstate, NY (Dutchess County)
    Quote Originally Posted by Spensar View Post
    The solar cover is actually poorly named. It's really a blanket that prevents heat loss (particularly overnight). Early or late in the season here in the Northeast one can lose several degrees in one night.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Westminster, MD.
    "Just a solar cover will do very, very, little to increase the temperature of the pool."
    you're joking right?
    My clear cover can get my pool well into the 90's (water temp is 86 today)
    I also believe a solar cover will increase your pool temps over the course of a sunny day - even a blue cover. I see it every day, and this season in particular have REALLY kept an eye on it because of all the controversy in this forum last year.
    Here's my case:
    My pool - 30 foot round (pool A)
    Neighbour's pool 24 foot round (pool B)
    - both located in identical locations 300 feet appart - full sun all day
    I use a cover, neighbour tossed his due to age this spring.
    Springtime - I didn't cover either - pool temps identical all the time every day.
    Once we got pools cleaned up, we both started to run the timers 9-5 on our pumps, I covered my pool up. My temps slowly started to increase, maybe half to full degree per day, some of that heat was retained overnight - yes, but every day I gained on his pool over the course of the day. after about 2 weeks, my pool was 7 degrees warmer.
    If I leave my pump off for a sunny day with a blue cover, the water for about 4-6" under the cover is about 98 degrees, once I turn the pump on for about 3 hours, the entire pool has averaged an increase of about 4 degrees - my neighbour's on the other hand may pick up 2 degrees in that same day without a cover.
    remember that evaporation cools while the sun heats, with a solar cover, you don't get the evaporation - therefore, more heat gain.
    project is now canned since I fixed my solar panels and they are now operational, so any further comparison is not accurate anymore.
    I also believe that the darker blue actually attracts a little more heat than a lighter blue liner would. - a black cover would attract even more, as long as it's able to transfer that heat through to the water it is in contact with, your pool would definitely heat up more.
    A clear cover would allow the entire liner (walls and all) to attract heat and because of the cover, almost no heat is removed due to evaporation - I have yet to find out which cover is best - clear - blue or black, however, I truly feel after this spring that a cover is certainly more advantageous than no cover.
    One last benefit you have with a cover is that you're not topping your pool up nearly as much as without a cover, and when you add water from the hose, it's really cold (about 65 degrees) compared to the pool water which could potentially lower your entire pool temp by about 1 degree if you need to add 3 inches.
    Default Bought a cover and a reel...
    Craigslist comes through again!
    http://hudsonvalley.craigslist.org/hsh/328292007.html
    New Horizone Elite HV-10 reel
    New Roebelle 18x36 Solar cover
    Both items were listed at $186 but the seller let me have it for $175. Couldn't pass that deal up!
    I actually have an old solar cover in pretty good condition that the previous owner of the house left with the pool so I threw that on yesterday. The pool cleaner seems to be doing fine underneath the cover.
    It'll be sunny with 82~90*F highs and 57~65*F lows this week so it'll be an ideal time to test the effectiveness (both temperature and FC consumption)
    Loop-Loc Mesh cover
