Results 1 to 10 of 12
Thread: thepoolcleaner pressure side cleaner... so far so good...
    Default Re: thepoolcleaner pressure side cleaner... so far so good...
    Tom,
    A booster pump will be WAY too powerful for ThePoolCleaner on a dedicated line. If you meant hooking up your main pump to the dedicated line in addition to the regular returns, then you are right that it might not be powerful enough, but having a switch valve to have most flow go to the cleaner would work (but then circulation might not be as good from the other returns).
    One other thing I forgot to mention is that ThePoolCleaner hose is thick -- I think it's 2" and it is noticeably larger in diameter than a regular pressure side cleaner hose. They have special fittings/adapters to convert the normal 1.5" screw for the return into their required fitting.
    To get the 15 GPM and roughly 14+ RPM from ThePoolCleaner (which, again, is on the high side of what they say is needed), my pump was at 2180 RPM going only to the 1.5" dedicated line. Most of the pressure (7 PSI out of 11 PSI) was from the cleaner as 15 GPM through the pipe has relatively little loss. So the high end of the cleaner operating range is 7 PSI (for the cleaner alone, incremental to losses in the line) and 15 GPM while the cleaner is supposed to operate at lower flows/pressures as well though my experience with some flow directed to other returns and a wheel RPM closer to 11 instead of 14 was that it didn't clean as well.
    Richard
    Jul 2006
    Thanks. I understand that the booster pump would not be needed and thus I could incur an electricity savings. For me the issue will be the effort, time and cost of having to replumb for a non-booster pressure cleaner. Like I mentioned in my first post, I am looking for next season so I have plenty of time for research.
    I do appreciate all the info you have given. Thanks again.
    Tom
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Just wanted to jump in here. I changed over a year ago from a 2 hp whisperflo and a booster-driven Polaris 280 to a 1.5 hp Ikeric and a suction-side The Pool Cleaner. I still have to run the Ikeric pretty high in the summer to get the solar heating to work well because of the design of my solar heating system (long story...) The Pool Cleaner is on whenever my pump is on. The pump runs on high when solar or my heater is on (there is a new JVA to the heater bypass that I have to activate to send all the flow through the heater whenever I want to use the heater and when that is activated, we set the pump to high so the water doesn't come out too hot into the spa--this was a patch that I don't like). The Pool Cleaner works at high or low speed and the suction on my pump is very low.
    Pros:
    -Saving A LOT of electricity cost. More than $100/month all year. Sometimes $200. This was great when my pool was in "freeze protection" for a large portion of our unusually cold winter last year. Really a huge savings.
    -Very simple design and pretty flexible (manually)
    -My water is clean
    -very quiet
    -overall system pressure is much lower. I have things set so the filter pressure is 11 psi when the pump is low and 19 when the pump is high. If I were to completely bypass the heater, which I probably should do, the pressures would be much lower. This all saves an incredible amount of wear and tear on my pool equipment and allows the filter to work much better.
    Cons:
    -not as easy to turn off the cleaner and remove it from the pool. I used to just press a button inside my house and unplug the cleaner. Now I have to change valving at the equipment. I don't think the pool remodeler really thought this through well enough and I wish they had shared their plans with me better up front so that I could tweak them (I have an instrumentation/controls background...)
    -Robs suction from the skimmer. Enough that I am not so happy about the surface circulation. The surface is never as clean as it used to be. A booster pump would eliminate this issue as it would pull (or push, as in the case with a pressure-side system) the extra needed through the pump. I now need to do more manual labor on my pool to clean the tile line. I have tried changing circulation patterns with the returns to little or no avail.
    There is much more, but I am happy enough with it to wait for the payback of all my changes before making more....
    Salinda
