Petrolium Product Floating on Water
I have an 11,000 gal Kidney shaped inground pool. Last fall during a very heavy rain and flood, my pool was blessed with a petrolium product floating across the surface. The amount seems to be very small, the thickness is less that that of a sheet of paper. It has made it into my pump/filter system. What approach should I take to remove it? Absorbant Pads? Chemical to break down oil? Draining Pool? Any help would greatly appreciated.
