I have a 24' AG with a 1.5Hp pump + Hayward sand filter that I run 8hrs/day, normally. The backwashed (ie: clean) pressure is normally around 14lbs. When I use my bug vacuum after a fair amt. of debris get on the bottom, the pressure in the return drops greatly. The pressure reading usually peaks at 18-20lbs. The only way I have been able to get the return jet pressure back up is by backwashing. However, the water in the sight glass doesn't get all that visually dirty (then clean) during this process. I see some specks in the glass, and usually backwash for 1-2 minutes. After a rinse, the return jet pressure is back to max, and the pressure on the dial is back to around 14lbs. My water is crystal clear.
Q: is this normal to have to backwash every time I vacuum when the pressure is only up 5-6 lbs? I've heard bad things about random backwashing, but this is the only way to get the return pressure back to normal. Thx.
