Re: MIGHTY SUN and AQUA LEADER POOLS????
We just had a 15X33 Aqua Leader Pool installed. The model is the Mirage with the "champagne bubbles" liner and it's a very attractive pool. I had an Artesian pool before and I'm just as impressed with the quality of this pool. This pool doesn't have the stainless steel panel, but I'm happier with only one row of bolts at the union of the wall intead of two. I'll support the skimmer when I build the deck anyway. This one is all resin..top and bottom rails, side support covers, and caps.
You can check out photos at webshots if you like. My screen name there is fcaputo. Use the "Oval Pool Installation" album.
http://community.webshots.com/user/fcaputo
Best Of Luck,
Frank
