Re: pump pressure
Only thing I can suggest is it sounds like a suction side issue since either a blockage or an air leak would cause a pressure drop. If it's an air leak the air bubbles will be obvious in the pump basket and bubbles will come out the returns. Is the pressure drop sudden or does it gradually decrease as you vacuum? Just another tidbit of info to help diagnose the problem. Also what type of filter?
