IMHO, a 3/4 hp pump is not affected much with the 1.5" PVC pipes. You will get better hydraulics with 2" pipes, but as Chris said, not enough to warrant replacing your 1.5" section from the Jandy valve to the pump inlet. Now if you were to replace all your PVC above ground to 2" plumbing, you will gain some flow and lower backpressure. This will be easier on your motor.
