Results 1 to 10 of 15
Thread: Large solar cover help
    Default Re: Large solar cover help
    Waste; Thank you for your input. It does not sound like my wife or kids are going to be able to roll a cover that large without help. I suppose I can just start with the liquid solar blanket and see how well that holds the temperature. At over $1,600 for a commercial reel and cover, this could turn into an expensive experiment, if the cover does not get used because it is too hard to handle or the pool does not get used for the same reason.
    Rich
    Upstate, NY (Dutchess County)
    Quote Originally Posted by srbaker View Post
    Rich
    Gaak!!! at $1600 aren't you approaching the cost of an automated cover?
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Leejp: Not even close. I have another issue I am dealing with. My insurance company did not like my pool fence arrangement. So have to put up a new fence. I looked into getting a automatic power cover, unfortunately that will not meet code, but the quotes i got were over $10k, and that is what the new fence is going to cost. I have new neighbors with little kids so while the fence is very expensive I want it done to code.
    My whole backyard is fenced in but I installed a removable fence last year from these guys...
    http://diypoolfence.webdirectbrands.com/
    Just wanted an additional level of safety. Now that I've got a solar cover it's even more critical (you can't see the kid under the cover... even accomplished swimmers can get tangled up in the cover...). But as with all safety devices, it's as good as the user.
    Loop-Loc Mesh cover
    I looked into that type of fence, the problem is it does not meet our code requirements, so I am going with a Jerith fence. Considering the length I need and since I want something that looks good, the $10k is really not that bad.
    Poughquag, New York, USA.
    I have a 20x40 IG. We got a large commercial reel because we wanted it to clear the diving board easily. It stands about 40" high and is ugly as sin. But it works very well. Although the cover does try to squirm when rolling, getting it OFF the pool is relatively easy. I can put it back on the pool by myself, but no one else can.
    We paid about 1200 for our reel. Its expensive, but we can move the entire thing completely out of the way when swimming. Plus, we can store the cover on the reel over winter, something that is not recommended with the less stout reels.
    while my pool is half the length, it's the same width..30 ft..in terms of putting it on, an easy and cheap solution i've used for 2 years now is a holeless grommit. basically a 2 piece tube that i locate about 2 inches into the end of the cover and then you slide one piece into the other to secure it. then i attach a thin nylon rope to it. i have 2 of these in place on my cover and it's easy for one person to pull the cover on by grabbing the 2 of these. 2 is quite sufficient to pull the cover on evenly. the ez grabbit is what i use (most hardware and camping stores should have. they are widely available...bought mine at the canadian tire store in canada) here's what they look like. they are cheap and work great and standup well to sun, etc. tough plastic:
