Results 1 to 10 of 16
Thread: adding cya
    Carlsbad, CA
    Default Re: adding cya
    A real clue that you are struggling still with algae is the FC dropping all the time.
    I didn't know that. I've been battling mustard algae lately. I don't seen any now, but I go through a gallon of chlorine (10%) a day (25k gallon pool). My CYA is at 40. I thought the loss was due to sunlight (so. cal) but maybe I haven't won the battle after all.
    What do you think?
    Thanks!
    jhm,
    See if the chlorine drops overnight. If it does, you've got algae or something consuming your chlorine. If not, then the losses are due mostly to sunlight.
    Richard
  1. Adding CYA
    By utahpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2010, 02:26 PM
  2. low pressure when adding DE.
    By Amir in forum Pool Equipment & Operations
    Last Post: 05-24-2009, 06:10 PM
  3. Adding BBB
    By Water_man in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2008, 09:00 PM
  4. adding cya to pools
    By cleland418 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 03:16 PM
  5. Adding CYA
    By satj in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2006, 11:07 PM
