Tips for Adjusting Water Jets
Greetings--
I'm searching for advise on adjusting the water jets on the sides of my IG pool.
Retanglular pool aprox 20x40. Skimmers on long sides at oposite ends. Jets are in the middle of each short side, one in step well, and another on side near steps. No jets on long sides.
I notice that debris flows mostly around the pool, but more towards the middle in a circle than along the edge . This causes most of the stuff to miss the skimmer openings. Overnight, the debris eventually makes its way to the skimmers. I'd like for the debris to flow across (and into!) the skimmers better.
Is there a trick to adjusting the direction of the jets to help direct the debris along the sides and across the skimmer openings ??
Point them more towards the surface vs under water ?
Point them more towards the pool edge ? This noticable reduces the flow rate.
Thanks--
