Results 1 to 10 of 13
Thread: Liner Deteriorated!!
    pcasey61 is offline ** No working email address ** pcasey61 0
    Default Liner Deteriorated!!
    Hi;
    I have had my pool for 11 years. The first 10 years I really only concentrated on keeping the Chlorine level in check, occasionally I would check and try to adjust the PH, but I never got too involved in ballancing the water too precisely. The water was always fine for swimming and the liner lasted 9 years.
    Last year, I started using the BBB method around the same time I got a new liner and the pool seemed fine. When I opened the pool this year, the blue liner was completely white below the water line. It just ripped and when I checked it, the entire liner was brittle and almost felt like it was paper. Could this be caused by using the BBB method, or could it be because I used too much bleach and hurt the liner. Any help is greatly appreciated.
    Indiana.
    Default Re: Liner Deteriorated!!
    Quote Originally Posted by pcasey61 View Post
    Sounds like pH was way too low. Unless the bleach was at an insane level, there's no way. What is in the water is no different with bleach than it is with any other chlorine, the delivery is just different.
    Ontario.
    pcasey, where are you located? Do you have a winter where to pool freezes solid for a few months, or stays unfrozen all year?
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    My pool freezes solid and the liner is just fine. My guess is also the PH.
    I am in Boston,and the pool does freeze for 3 months.Also,I have been leaving it uncovered all winter. Might this have an effect?
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    FWIW, I'm upstate NY with a 7 year old liner (Imperial). I only use a leaf net over the winter and mine hasn't shown any degradation in two years of ownership (and BBB).
    pcasey61,
    I have a list of questions for you and please don't be offended by any of them. I just want to try and figure out what is different from before. Of course, the problem could just be with the new liner itself. With our opaque safety cover, it started to wear through in one area after only 2 years even though it has a 7 year warranty. The warranty pays full replacement cost up to 3 years so we had it replaced last year and the new one seems much more supple than the first one (even during its first year). The installer said that they sometimes get a bad cover but most last longer (usually 5-9 years -- hence the 7-year warranty).
    What was your source of chlorine before you switched to BBB? I believe from your previous posts that you put chlorine pucks in the skimmer, is that right? I assume these were Trichlor, but were they BioGuard Smart Sticks designed to be put into the skimmer or were they regular Trichlor pucks? Was the pump running 24/7 and if not, for how long each day?
    In this thread of yours last year on June 19th, you wanted to switch to BBB and you found your chlorine level at zero and was eating right through the pucks. You also got no reading on pH (I don't understand that) and that the pool store said your pH was well below 7 and that the Alkalinity was 0. Was this situation AFTER you got your new liner? If so, then the very low pH was most likely the cause of the problem this year.
    How have you been adding your chlorine (bleach?) to your pool? Is the pump running when you add the chlorine? Do you add it slowly over a return or into the skimmer or distribute it around the pool? Did the vinyl tear occur in the area where you regularly pour chlorine (if you pour it in the same spot each time) or did it occur on the sunny side of the pool?
    Richard
    Michigan
    If it was me, I'd call the people who installed the liner and see what they have to say about it. Also I'd check with my homeowners insurance. A friend of mine said his insurance would pay for a replacement liner when his wore out. That seems odd to me, but he swears that's what they said they'd do.
    Also, it took a few years of low PH due to pucks before our liner finally turned white and wore out. I wouldn't think low PH would do it that fast??
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Don't buy the insurance thing, insurance covers sudden and unexpected loss not gradual wear / loss.
