Results 1 to 10 of 18
Thread: ph keeps falling
    Default Re: ph keeps falling
    I would shock the pool. At the CYA level of 30 ppm you reported, I would shock to at least 12 ppm FC (Ben's chart says 15 ppm so you can do that instead -- 30 ppm CYA is at the low end of the range) and hold it there until the following three things occur: 1) water is crystal clear (it may already be), 2) FC does not drop overnight or does so minimally (0.5 ppm is on the edge), 3) you do not measure any significant CCs (< 0.5 ppm). So your measurement overnight is on the edge so shocking would be reasonable to do.
    worcester, ma, uas.
    okay, will do, I have company coming for the 4th so probably a good idea anyway. The water is crystal clear, but I want to make sure it stays that way. The temp will be cool this week (low 70's day/ 50's night) the water temp has dropped to 76. even with the cover on all day and night.
