Thread: Nitelighter not fitting AG Emerald Isle pool?
Threaded View
  1. #2
    Default Re: Nitelighter not fitting AG Emerald Isle pool?
    You are supposed to remove the top rail, hang it over the wall and reattach the top rail. If your top rail "pinches" the wall with a U shape, you will have to change your mounting method and adapt as necessary.
    If your top rail is double walled - ie - cross section like this (roughly):
    |___||___|
    and the two verticals in the middle are too close together to cap the light top, the I recommend you just screw the light upwards into the top rail from underneath just inside the pool wall.
    Edit - I just looked at your pool - it's resin, so yes, it'll pinch the top of the wall, and the width of the nightlighter is too wide - so, one of three choices -
    1. do as I stated above and screw in from underneath.
    2. Return it and buy an aqualuminator light - my choice - better light anyways - and get the LED model while you're at it.
    3. Dremmel the area out of the resin top rail where the light should go.
