jdw, while the pool store's advice would probably work - killing the algae with a sufficient dose of bleach and letting it settle to the bottom would probably also work. Ben had a 'riff' about... 'any chem you add to a pool will do something, often the desired result, but will also cause a problem that you didn't expect' -- The point is that if you just start adding 'Miracle X' chems, there will be a 'backlash' problem - POP (pool owner patience) is most often the BEST way to deal with a problem [something that took months to cause usually can't be cleared up in a day!!]
