Results 1 to 10 of 19
Thread: i'm running my pump at night. bad idea ?
    North Florida
    Default Re: i'm running my pump at night. bad idea ?
    An Intermatic PF1102-T (has freeze protection). I believe the newer model of mine is this one: http://www.intermatic.com/Default.as...cid=71&sid=348
    The only thing I would do now is get this type timer that can actually handle 2 different timing sequences: one for the pool pump and one for the Polaris cleaner. As it is now, the Polaris would be on all the time the pump is on unless I manually turn the Polaris switch off.
    Sandy
    keithw is offline Registered+ Thread Analyst keithw 0
    Just out of curiosity, for those who say that they get a lower rate at night so they run their pools at night. How does the electricity know whether you are using the power at night and not during the day to give you that lower rate? I am in VA and I had heard the same about our electric company as well. BUT...The only meter I have at my house is a electric meter on the house with a spinning wheel and numeric readings. They come by and check it every once in awhile (I guess!) but certainly not every morning. It doesn't have any other reporting back to them built into it so I don't see how they would know either way.
