Results 1 to 10 of 11
Thread: How / Where Do I buy Liquid Chlorine?
    Middle Missouri
    Default Re: How / Where Do I buy Liquid Chlorine?
    I didn't think of the salt water chlorine generators. They're kind of expensive, right? Off I go to Google. - Jim
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
    Jul 2006
    SE Georgia
    Liquid chlorine is simply just chlorine bleach - plain old laundry bleach.
    Buy it at Walmart, or buy it at your local grocery store. Just make sure you shop around for the best price!
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    Scottsdale, Arizona
    Quote Originally Posted by cheshamjim View Post
    this is the one I use and like it so far ....
    http://www.balboainstruments.com/page218.html
    Middle Missouri
    Thanks for the link Philbo. Wouldn't you know; they have no dealers in my Zip code. I'll call them. -Jim
    Jim
    PS234 test kit
    Ontario.
    Check out a farmer co-ops and industrial cleaning supply companies.
    I'm lucky to get 12.5% in a refillable carboy from a cleaning supply company who also supplies a lot of the municipal pools with chlorine. It's easy since you drive right up and they put the filled carboy into your vehicle for you. Hmm, funny that this chlorine will all that "inert water" is good enough for public pools.....
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    There are many different SWG out there at a wide range of prices. Do a search on this site and you will come up with a lot of different posts on what others have, how much they paid, etc. You can get systems for IG pools starting around $470ish - all the way up to several thousands of dollars. These include on the low end of the price scale the IG Chlorease CLO3, going up to the Aquatrols, Pentairs, Zodiaks, and the Pool Pilots with all the bells and whistles. Many brands and many different types out there with lots of satisfied customers.
    Middle Missouri
    Thanks to all who responded to my post. There's some very good leads here and I know I'll be able to get what I need because of you.
    Beast regards - Jim
    Jim
    PS234 test kit
    Upstate, NY (Dutchess County)
    Default This is my last year with Bleach...
    I'm quickly coming to the conclusion that when all costs are factored in that salt water chlorine generators are more economical. Especially when gas is over $3/gallon.
    Not counting startup and closing... I figure I go through about 100 jugs of 96oz 6% bleach or about $130/year + transportation. If a chlorine generator cell lasts 4 years I think I'm just about even. Anything beyond that I save $$$.
    Plus I'm too lazy even to open a jug of bleach and pour it into the skimmer once per day or two.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
