Re: Effects of PH
I'm with you Richard, from reading this forum I always thought it should. I use the Taylor kit, and bought new CYA Reagent just to be sure, but that little black dot never even comes close to disappearing. For the record, I diluted the pool about 25% early in the season - see later for the reason.
I have a cartridge filter (that I've washed 3 times this year) and little rain enters due to the solid cover on the pool.
To stay on topic though: is low pH OK for concrete? Or as you're possibly identifying, maybe I've got testing problems.
One other potential gotcha: early in the year, I lowered the TA to zero with a mess of muriatic acid in order to remove some tough stains with Jack's Magic. It actually worked to remove the stains (that two visiting pool companies had failed to identify or do anything about) but definitely pulled some calcium out of our walls (thus the need for dilution.) Maybe that is still affecting the balance?
