Results 1 to 3 of 3
Thread: HTH 3-in-1 pucks
    Oct 2004
    NJ, USA.
    Default HTH 3-in-1 pucks
    Anyone have experience with the HTH 3-in-1 pucks? Any better than Tri-Clor pucks? Can I use the HTH 3-in-1's in my clorine feeder?
    Default Re: HTH 3-in-1 pucks
    If they are what I think they are, they are HTH's Tri-Chlor pucks plus copper.
    STAY AWAY FROM THEM! While copper is an effective algaecide, the cure is worse than the disease. Chlorine is still the best algaecide.
    HTH's web site doesn't list them, but does list "double-acting" tri-chlor tabs, conveniently omitting that the second action is from copper.
    I find that when pool chem companies try to introduce some new "cocktail" product it's usually NOT what you want, and adds something you don't want or need.
    IMHO
    waterbear's Avatar
    St. Augustine, Fl
    These pucks contain a copper based algaecide and a clarifier. Not the best choice to use, IMHO.
  1. Floater pucks VS Skimmer pucks
    By ThaSatelliteGuy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2011, 07:11 AM
  2. Pucks
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2007, 04:43 PM
  3. PH and pucks
    By aguaguy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-15-2006, 12:37 PM
  4. Do pucks get old?
    By Deuce2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2006, 10:03 AM
  5. pucks?
    By pairadocs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 03:21 PM
