Results 1 to 10 of 16
Thread: Are All Main Drains Created Equal?
    elsie is offline Registered+ Thread Analyst elsie 0
    Default Are All Main Drains Created Equal?
    Anyone who heard yesterday of the young girl eviscerated/disemboweled by the main drain in a kiddie pool (a kiddie pool, mind you), I'm sure, has heartfelt empathy for the girl and her family, and perhaps some wonder a bit about the safety of their own main drain.
    Some months ago I posted a question asking what the purpose of a main drain was and, not getting a response, I figured it was a dense question for what purpose could a main drain have other than to, well, drain the pool? I have yet to replace the liner in my inherited pool of five years now, but my guess is that when I do, that main drain is configured with PVC to take the water into the groundwater system?
    Are the main drains in commercial pools different? Are there pumping systems located beneath them such that it was not the gravity of water alone that caused this horrific accident, unlike the drains in our pools where the pumps are geographically removed and have no connection to that drain? Otherwise, how could the limited water in a kiddie pool create such a powerful vortex to do what it did? (And on an entirely other subject, why in hell's name haven't they covers that are so fiercely bolted down they cannot possibly come loose, and in fact, require a diver with wrenches to open?)
    If the screws beneath the grate of my main drain came loose, and I were swimming along the floor of the deep end (or floating on a raft overhead), would I be sucked flush with that grate by the forces of exiting water and drown?
    What can anyone tell us about main drains, their function, and if commercial drains differ from residential drains?
    Indiana.
    Default Re: Are All Main Drains Created Equal?
    The main drain in a home pool is connected to the pump, and it is subject to the same type of accident EXCEPT all pools are required to have drain covers that prevent it. The operator of that pool is in serious trouble for allowing it to be operated without the drain cover.
    The main drain is misnamed. It has nothing to do with draining the pool. It is a source of water for the pump.
    Oh I'd say worse than serious trouble. Megabucks lawsuit.
    John, if the main drain's function is as a source of water for the pump, where's the source of water if that drain is closed/covered/never opened? Why even have one? It's clearly not pulling water from the pool. I thought the pump recirculates water via the skimmer pvc and the returns?
    Indiana.
    Quote Originally Posted by elsie View Post
    Water is drawn into the pump from the skimmer(s) and the main drain and sent back to the pool through the returns in a typical pool installation. I'm not sure why a main drain would be installed if it wasn't opened, but it is fairly common to cap one if it starts to leak. Their only function is to provide water to the pump except in gunite pools where they also have a hydrostatic relief valve to relieve external water pressure when the pool is empty.
    Interesting. So then e.g., you could dive down to your drain and feel water circulation? I've dived down many times out of curiosity to look through the grate of my drain, wondering what its purpose is. I have my mask on and have put my hand over the grate and looked at the 4 screws beneath it that presumably keep the cover on. There is no draw from that drain. It is completely closed. That's why I assumed it's function was to drain the pool. Of course the more I think about it, that's not even logical, because if there's that kind of suction from the drain when opened, even a diver would be in peril.
    So if there's circulation there, in other pools, that means the cover is off? Why doesn't it suck people to it? In this commercial kiddie pool where the girl was almost fatally injured (and whose life is forever altered) why would the drain be closed in the first place if its function is to add to the circulation of water?
    Sorry for all the questions, John, but still confused.
    Mandeville, LA, USA.
    elsie,
    Depending on how your pool is plumbed, you may have a valve that controls flow from the main drain. If that's closed, you won't have any suction there. As JohnT said, your drain could also have been intentionally capped because of a plumbing leak. It could also just be plugged up with something.
    Modern pool drains have anti-vortex covers that minimize the sucking force generated by the flow of water. Main drains are also installed in interconnected pairs that are placed a couple of feet apart so that, without being extremely large or extremely flexible or both, a person can't seal off the main drain and become entrapped. There's still some danger though as one of the main drains could be blocked by something (deflated pool toy comes to mind) renedering the other one a hazard to an incautious swimmer. The anti-vortex cover would still make entrapment unlikely but it's definitely possible in such a scenario. Couple one blocked main drain with a missing or old style cover on the other and you've got a tragedy waiting to happen.
    I generally keep my main drain valve at the pad closed. I do that as a safety precaution and to maximize flow through the skimmers.
    Indiana.
    You can't feel the suction. All main drains are supposed to have a cover on them, but the water flows through the cover. A common design for the cover is a raised flat surface with the openings around the edge. It looks solid from above. Go to this link for drain info and pictures: http://www.drainsafe.com/print_summary.htm
    Here is a picture from the above page:
    with a cover like this it would be almost impossible to have an accident like the one talked about.
    Thanks all. I understand better now. The cover by definition, contrary to what I was thinking, does not necessarily preclude water intake, but rather by design mitigates the intake as I see in the picture (depending on the situation with the valve below it). And that's just how my cover looks, although I'm not sure I can visually see those vertical sides, but I do see the plate and screws.
    It would be interesting to know the history, i.e., why mine does not function as part of an integrated whole. Maybe a leak as suggested. It's also worth noting that apparently whether or not that main drain is completely closed off or not doesn't seem to affect the efficiency of water circulation, or problems associated therewith. Of all the posts I've read, I've never read "yeah, my main drain is closed because the valve leaks so I don't get good circulation and tend to get algae."
    So back to a chicken-and-egg thing, if the circulatory system works fine without use of the main drain, why did they install them in the first place? And do they still?
    There is a lot of arguement as to if they are needed or not. In a "Perfect" engineered design you probably don't need one. But, most pools are far from perfect and having one will improve circulation and help maintain a much more steady temperature. Remember that heat rises, so the bottom of the pool will tend to be much colder. By pulling the cold water off the bottom you mix it better with the pump and eliminate thermal gradients in the pool, not to mention circulating chemicals better.
    If there were no reason for them you can be certain contractors would not install them as they cost money.
