Thread: Using 12.5% chlorine
    NW Oregon
    Default Using 12.5% chlorine
    I need to supershock my pool. What is the best way to add 12.5% liquid chlorine? Through the skimmer or over the side? My vinyl liner is already losing its pattern from pouring the 6% stuff over the side.
    34 X 22/15 inground vinyl w/ Hayward equipment
    Mandeville, LA, USA.
    Default Re: Using 12.5% chlorine
    If you don't have an inline chlorinator, adding it slowly to the skimmer should be fine. If you do have an inline chlorinator you should never add any form of chlorine through the skimmer.
    NW Oregon
    Carl do you agree? I know his vacation strategy is to have someone add chlorine via the skimmer every other day but it's probably not 12%. I do have an inline chlorine injector but it is designed for trichlor pucks. I used the bleach calculator and added 2.5 gals through the skimmer so I hope it doesn't eat anything.
    Carl does add bleach via the skimmer, but he doesn't use trichlor pucks. The danger with adding bleach (or liquid chlorine) through the skimmer with trichlor in the feeder is the possibility that the chlorine will react with the trichlor before it's sufficiently mixed with water, and cause a chemical reaction that is explosive. I would stick with adding it "over the side", but if you will pour it slowly in front of your return, then the jet from the return will disperse the chlorine before it has a chance to eat up your liner.
    NW Oregon
    Thanks for the caution! My feeder is empty and turned to 0 so it shouldn't be a problem (I hope).
    I'd run the chlorinator wide open for a day or two, just to make sure all the tri-chlor is flushed out, and then close it (turn to zero) before adding bleach through the skimmer.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
