Chlorine went up unexpectedly
Been using the BBB method since opening my 30000 gal inground concrete pool in May this year. Water has been clear and no algae problems. I have a DE filter and a Nature 2 system so been keeping chlorine low 1-2ppm with no problems and water has been crystal clear since May 2007 (it was clear when I opened the pool also. I last shocked the pool in mid June 2007. 4 days ago we had a big rain (2 inches), but my free chlorine levels (FC) held at 1-2ppm. I usually add 60oz of chlorox each night and FC has been maintaining 1-2 ppm without issue during the day. (my pool gets full sunlight). 2 days ago, my FC dropped during the day to 0.1ppm for no reason-I quickly added chlorox for a 1.5ppm increase and measured it the next morning. Again, the FC dropped to 0 during the night, so I added another 136 oz dose of chlorox plus a 1lb bag of CaHypo that morning (yesterday morning) and measured FC during the day-it was 5 ppm (as expected after this add) and slowly decreased to 3.3ppm by the end of the day (yesterday) (not too bad since sunny all day). So, that evening (last night) I shocked the pool with 4 large jugs (1.4gal) of chlorox or 5.6 gal total which should have been an 11ppm increase.
2 hrs later (last night) I measured FC and it was 22ppm and the pool was cloudy-barely able to see the main drain (8 ft of water). pH also had gone up to 8.2 from the chlorox add. The next morning (this morning) it had decreased down to 16ppm (and pH went down to 8.0). The water this morning has cleared up approx 50% as I can now see the main drain clearly although still some cloudiness in the water. At this point I back flushed the DE filter as the back press had risen from 21psi to 27psi during the night (went up 6psi after shocking).
Question is, where did the chlorine come from? The FC is way higher than I added, so it appears the chlorine came out of some "black hole" after shocking. I have been measuring FC with both OTO Taylor drops and my LaMotte DPD colorimeter, so I think the high chlorine was a true reading as they both compared before and after the shock (had to dilute 1 to 3 after the shock to get a reading within range).
Any ideas why my chlorine rose to 22ppm when I only added enough chlorox for 11ppm? (5.6 gal).
My latest chemistry shows pH a little high (it is coming down as the chlorine level comes down. Here is my chemistry before and after the shock. Pool temp = 85F. I expect pH to continue to decrease so I have not added for pH, plus the water is in balance at this point.
Any suggestions of what happened would be appreciated. I will be adjusting pH as needed after my chlorine comes down due the the sun
Before shock
FC 3.3/TC 3.5
pH 7.6
TA 75
CH 218
CYA 46
water clear, DE press 22psi
After shock
FC 16/TC 16
pH 8.0
TA 80
CH 218
CYA 46
water slightly cloudy, DE press 27psi
Don
30,000 gal concrete pool -- Autopilot SWG
Using BBB for chemistry -- Using LaMotte ColorQ for testing
