Thread: lowe chlorine after shock
    tagprod is offline ** No working email address ** tagprod 0
    Default lowe chlorine after shock
    How do you lower chlorine after shocking? My CYA is 70 so I got my shock levels up to about 35PPM. I haven't added any chlorine or ran my SWG for a couple of days and my FC is still way over 10. I used some of jacks after shock today, but I only think it's going to drop my chlorine by 2 or 3 PPM. Is there a cheaper alternative?
    mbar's Avatar
    Ashland, PA
    Default Re: lowe chlorine after shock
    I wouldn't worry about it - you can swim with it over 10ppms without any fading of suits in a pool with cya of 70. Your goal chlorine levels with 70 cya is between 5 & 10. I would just let nature take it's course
    Northeast PA
    Gracias! I'd just like to know how far over 10 I am so I can hopefully( if the weather cooperates) swim on July 4th.
    Leave the cover off, and it should drop by the 4th with no problem.
  1. Question about shock and chlorine
    By donovan.lambright in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-29-2012, 05:20 PM
  2. How much chlorine does shock add
    By pbotz2000 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2010, 01:59 PM
  3. Chlorine-less Shock
    By mphare in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-12-2007, 08:29 AM
  4. What is non chlorine shocK?
    By szcakes in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 07:07 PM
  5. Do I need to shock if losing chlorine?
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 01:51 PM
