Re: pool pump
Kerrie,
What was the pressure when the flow was nil? If it was zero then there was a suction side block or for some reason the pump lost prime and could not reprime. If the pressure was high then the filter was probably just plugged with dirt and backwashing solved the issue. If flow was stopped because of a filter block and subsequent high pressure then you are lucky. With no water flowing in the pump the pump will just heat up the water that's there and do heat damage the pump housing and/or the pipe fittings. If you have even a little flow this won't happen. Did you have an unusually high amount of dirt in the pool or an algae bloom that could have plugged the filter? I also assume you have a sand filter.
