You pH is probably a lot lower than 6.8. That is the lowest that phenol red can test. I would start putting in borax to get your pH up to at least 7.4 and then retest your TA. If the TA test is turning red immedaitely it means 0 ppm TA and that is probably because of a very low pH.
