Your high pH reading is misleading as many pH tests are not accurate at high chlorine levels.My latest chemistry shows pH a little high (it is coming down as the chlorine level comes down. Here is my chemistry before and after the shock. Pool temp = 85F. I expect pH to continue to decrease so I have not added for pH, plus the water is in balance at this point.
