Re: AGP Oval Pictures
I have an Oval pool installation question.
Before we put up the track, I believe I read on this board to lay down some "crusher run" first. Should we dig a trench where the track will go
then fill it with the CR or do we just put the CR on the ground then put the
track up?
Here is the post I am referring to:
" Re: Oval Pool Set up with pics and tips?
My Recommendation to you is to build a 2" wall base out of compacted screenings (crusher run), this will "lift" your walls to accomodate the 2" of styrofoam and put everything back on the same level. The compactor will likely run you about 30 bucks for the day, you'll probably need 2-3 yds of screenings since you'll want them to go well beyond the edge of your bottom rail."
Do we do this to ours even though we have a J-Hook liner? It is the type that hangs off of the wall.
Thanks in advance. We are still working on the new fence. I will post pictures of the install.
Rhonda
