Re: Acid Rain
I think the pH of "normal" rain is somewhere in the 4.0-5.0 range; "acid" rain is marginally lower. But, as chemgeek explained here or over on troublefreepool.com, rain is a weak acid and therefore doesn't have the pH lowering effect you might think it would. As you implied, it actually raises pH in many instances because of the aeration it provides.
