Results 11 to 16 of 16
Thread: Are All Main Drains Created Equal?
    elsie is offline Registered+ Thread Analyst elsie 0
    Default Re: Are All Main Drains Created Equal?
    I think the pic Cleancloths posted is mine:
    Sta Rite 8" Anti Vortex 0712-0741
    Manufacturer: Sta Rite
    Maximum Flow, ANSI/ASME A112 Rating
    60 GPM
    This cover is A112 approved at 60 GPM
    The Sta Rite cover is flat on the top with a circle in the center. Water is drawn in on the elevated sides..
    _________________
    If the valve were open, I would not be able to feel water being pulled in? SO maybe mine is open after all? I'll dive down this weekend with a vial of dye to see, just for the heck of it.
    IL.
    I have an 15+ year old 16'x32' IG vinyl liner pool, 3.5' shallow end and 8' deep end. One skimmer, one main drain centered in the deep end and one return paralleling the 16' side in the shallow end. With only one return it needs the main drain to ensure adequate circulation, and I run both the main drain and skimmer wide open, closing the main drain only when vacuuming to maximize suction.
    My main drain has a circle grate cover. The actual 1.5" outlet is in the side of the "bowl". Although you can feel the flow when you cover the grate with your hands, it is well dispersed since the cover is 8" from the 1.5" outlet so suction is minimized. I can't imagine anyone getting stuck to it.
    I guess the cover would have to rupture somehow (earthquake, or a shift in the ground), then depending on the GPM, it could hold a person to it?
    How in the world do you close that drain to vacuum without diving down and manually closing it?
    IL.
    There is a valve before the pump that shuts off the main drain line.
    How handy is that. My pool's about the same vintage, too bad it doesn't have one of those.
  6. #16
    IL.
    elsie, if you have enough exposed pipe between the ground and the pump, valves can be added, either DIY or paying a plumber to do it.
  1. Navigator stuck on main drains
    By Madty in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-14-2006, 07:31 PM
  2. How do main drains work?
    By abessellieu in forum Pool Equipment & Operations
    Last Post: 08-09-2006, 06:47 PM
  3. Residential Main drains
    By Mark Hunter in forum In-Ground Pool Construction and Repair
    Last Post: 08-08-2006, 05:40 PM
  4. Two Main Drains or a Safety Switch?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 12:09 PM
  5. Plumbing of main drains and skimmers
    By eljefe281 in forum In-Ground Pool Construction and Repair
    Last Post: 06-13-2006, 12:31 PM
