Re: Pump pressure?
Tape is wrapped around the top of the center pipe. Only takes a couple layers and I had to keep trimming, removing layers of tape, to get a good fit. You're increasing the diameter of the inner pipe from the laterals where it mates to the pipe in the valve assembly so the slip clearance between the pipes is reduced. You still want air to bleed out of the top of the sand chamber, but not as fast as the original design.
