Help! have put 10 lbs of Stabilizer into my pool and still get a zero reading. Here are my stats:
Pool 20x40, 8 ft deepend, liner
cya 0
chl 0
free Chl 0
ph 7.8
alk 120
It is clear and I have kept the chlorine at 1-3, but it rained yesterday and when I just checked it it was 0 again. i am putting the stabilizer in with a sock and each time I test it, I still get 0. How much should I need??
Also, I am using new chemicals from Taylor, so I think they should be good.
Thanks,
Either you don't yet have enough for a reading (I THINK you need 15 lbs for your pool--but don't take that as gospel), or you are testing incorrectly, or you didn't add as much as you thought, or you've replaced more water than you realize.
