Thread: Skimmer Question
    Jul 2006
    Maryland
    Default Skimmer Question
    Can anyone tell me what the two pipes running down from my skimmers are? One seems to provide the suction when the pump is runnung, and the other one was closed off with a little cover. I let some DE get down there when I replenished the DE after I backwashed. Is that going to cause problems?
    Is there ever any reason to uncover the hole, or to move the cover from one to the other?
    Larry
    Jul 2006
    SE Georgia
    Default Re: Skimmer Question
    Apparently, it's there for different configurations.
    I would assume the most everyone uses the "basic" set up.
    I would venture to say there's a good chance that nothing is connected to the skimmer under that plug.
    See the attached link for some explanations.
    Hayward Skimmer Manual
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    Jul 2006
    Maryland
    Thumbs up Re: Skimmer Question
    Thanks. This is helpful.
    Larry
  1. Skimmer installation question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2012, 03:07 PM
  2. Fall closing skimmer question
    By nisqu in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-22-2009, 01:16 PM
  3. Skimmer and return question.
    By errodr27 in forum Pool Equipment & Operations
    Last Post: 06-04-2007, 02:55 PM
  4. Closing Question - Aqua Cover(skimmer)
    By jrv331 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-12-2006, 07:26 PM
  5. Newbie Question “what is adding a sock” to the skimmer
    By slater1182 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-07-2006, 01:23 PM
