Results 1 to 10 of 12
Thread: Chem_Geek: Heeeeeeelllllllpppppppp!!!
    Default Re: Chem_Geek: Heeeeeeelllllllpppppppp!!!
    Thiosulfate is supposed to reduce chlorine directly and not form combined chlorines. There are many possible reactions, but one of them is the following:
    Na2S2O3•5H2O --> 2Na+ + S2O3(2-) + 5H2O
    2S2O3(2-) + HOCl --> S4O6(2-) + OH- + Cl-
    There are other reactions that take the thiosulfate all the way to sulfate or even sulfur, but I believe these are less likely. None of them form combined chlorine -- all produce chloride ion. The oxidation potentials are as follows:
    2S2O3(2-) --> S4O6(2-) + 2e- ..... Eo = -0.08V
    S2O3(2-) + 6OH- --> 2SO3(2-) + 3H2O + 4e- ..... Eo = +0.571V
    2x( SO3(2-) + 2OH- --> SO4(2-) + H2O + 2e- ) ..... Eo = +0.93V
    S2O3(2-) + 10OH- --> 2SO4(2-) + 5H2O + 8e- ..... Eo = +1.501V
    The above reaction would result in the following with chlorine:
    S2O3(2-) + 6OH- + 4HOCl --> 2SO4(2-) + 5H2O + 4Cl-
    or equivalently
    S2O3(2-) + 4HOCl + H2O --> 2SO4(2-) + 6H+ + 4Cl-
    Thiosulfate Ion + Hypochlorous Acid + Water --> Sulfate Ion + Hydrogen Ion + Chloride Ion
    or
    S2O3(2-) + 4OCl- + H2O --> 2SO4(2-) + 2H+ + 4Cl-
    which is very acidic. My experience from using thiosulfate drops in high chlorine (but < 10 ppm so as to not significantly affect the pH test directly) water and its affect on the pH test is that the reaction is alkaline, not acidic, so I believe these latter reactions don't occur. If we calculate actual oxidation potential for the 8 electron reaction then RT/nF = 8.314472*300/(8*96485.3415) = 0.00323 while ln(10^(14-7.5)^10) = -149.7 so the actual E = +1.501 - 0.00323 * 172.7 = 1.502 - 0.483 = +1.019V. This is still a very likely reaction so perhaps the rate of the reaction is slow (high activation energy?).
    Richard
    LexPlayer is offline ** No working email address ** LexPlayer 0
    Richard
    Between your post and the chemical anlayis on this page, my eyes have gone buggy!
    If Professional Pool Operators of America (PPOA) is correct, I would think that Sodium Sulfite is a better option than Sodium Thiosulfate beause there is no free Sulfur floating around "sulfinating" the water up.
    I assume the Sodium sulfate (or Glauber's salt, sodium sulfate decahydrate, Na2SO4·10H2O per wikipedai) is just diluted into the water.
    Anyway, I still don't know what my chlorine level is, but I'm trying to find a DPD test kit locally.
    Do yourself a favor and forget the DPD kit and get an FAS-DPD kit. It's easier, more accurate, and can test much higher chlorine levels with an accuracy as great as .2 ppm!
    Evan's right--you are just wasting money--and you'll have to get a FAS-DPD test kit sooner or later anyway.
    DPD only goes to 15ppm before it bleaches out--looking like you have NO chlorine!
