Results 1 to 10 of 12
Thread: New to BBB
    Default New to BBB
    Can someone please tell me what I should do? I'm new to the BBB method and I have an 18 x 38 ABG with a 6.5 deep end. We started with new water about 3 weeks ago due to having to drain the pool.
    My numbers today according to the HTH test kit from Wal-Mart are this:
    Alk - 170
    Ph - 7.2
    Chl - 5.0
    CYA - 58
    My water is kinda of a milky white. You can see the shallow end, but not the deep end.
    How can I fix this?
    Thanks for any help
    Kerrie
    Default Re: New to BBB
    Have you added anything to your water other than bleach? List everything that you have added. Also, have you let your chlorine level drop? If so, your cloudy water may be the result of algae. You should be running your pump and filter 24/7 while you are fighting cloudy water.
    Actually the chlorine level had dropped from about a 5 two days ago to about a 1 yesterday. I added a gallon of bleach and that raised it back up to a five. This all started with buying chemicals at the pool store and me deciding I could do the basic stuff (with your help) myself.
    My first numbers on Saturday from the pool store were:
    TA - 20
    CYA - 0
    PH - 6.5
    TH - 30
    Phosphates - 500
    TC - 0
    FC - 0
    I added about 20 boxes of Arm and Hammer, 2 boxes (4lb boxes) of Borax and two gallons of bleach. I also added 8 lbs. of UV shield, 1 bottle of phosaway, and 1 bottle of Polyquat 60. (This is not the exact order, would that make a difference?) After the phosaway is when the water started to turn whitish in color.
    I haven't been able to test the water this morning, but will this afternoon.
    Can you also please explain or give me the link to find out exactly how much your Ph changes with what amount of borax. (Same for alk.)
    Thanks so so so much for your help.
    Kerrie
    Hi, Kerrie,
    Wow, you have quite a coctail there....the first thing that you need to keep in mind is to add things in small amounts, and one at a time, to keep things from really getting out of hand and making a mess like the one you have on your hands. First of all, the amounts of arm and hammer and Borax that you added at once are probably the majority of your problem. Did you add them through the skimmer, or broadcast them over the pool? Make sure that you're keeping your pump/filter on 24/7, and that should help clear it up if it's suspended powder in your pool.
    Secondly, your pH change with a given amount of Borax is going to depend on your total alk and pool size at the time you add it. Generally it's best to start with a small (or in your case with a very low pH, medium) dose of Borax, give it a little time to circulate, test, then adjust as needed to get to your target. Same goes with alk--it's best to add a little, then test and add more, since lowering alk if it gets too high can be done but it's a pain to do so. Also, the next time you find yourself needing to raise your pH and your TA, use A & H washing powder--it'll raise both pH and TA at the same time.
    Third, I hate to tell you this, but you got pool-stored with the phosaway, which you don't need--phosphate removers are a great scam for pool stores to sell you something that you don't need and make large profits for themselves. I'm assuming that the "UV shield that you added was CYA, or cyanuric acid. If not, add that to the "pool-stored" list. If so, did you broadcast it, or add it through the skimmer? If you broadcasted it, make sure to vaccuum up any that's sitting on your liner and let it dissolve in your filter. If it went in through your skimmer, make sure you don't retest for it or backwash your filter for about a week, because that's how long it takes for it to completely dissolve. Also, I don't recall offhand the gallonage of your pool, but keep in mind that once your stabilizer is in the pool, there's no getting rid of it to lower the levels except to drain and refill, so you don't want to go overboard on that, either.
    The polyquat is okay, but it isn't necessary if you keep your chlorine at appropriate levels, and the addition of polyquat after you add chlorine will completely deplete your chlorine level, so you'll need to add more to get it back up again.
    I hope this helps. You can do BBB without many problems, but don't let the pool store sell you stuff you don't need--that's the whole point of the BBB system!
    Thanks for your help...
    I realized after reading this site, that I was pool stored . I think the UV shield was CYA, and I added it through the skimmer. However about two days after adding, I did backwash for a little bit. What will that cause?
    We have had ALOT of rain here and I think that with leaving the pump on 24/7 has caused the water to clear up significantly.
    Can you please answer a couple more questions?
    What is stabilizer? Is it CYA? Our pool is 23000 gallons and the last test I did at home the CYA was about 55. Also is there a chart on how much to add (like 1 box of A&H washing powder will raise ph and alk. certain ppm).
    Cyanuric Acid (CYA) is stabilizer.
    It slows down the breakdown of chlorine, especially by UV rays. Without it your chlorine can vanish in as little as 15 minutes.
    But it's a two-edged sword. It slows down chlorine breakdown in EVERY way, including what you want chlorine to do---sanitize your pool.
    There's a chart, called the "Best Guess" table that tells you how much chlorine you need depending on your CYA level. The more CYA, the more chlorine.
    North Florida
    Quote Originally Posted by minermom View Post
    We have had ALOT of rain here...
    Backwashing and draining off excess water from rain will also drop your CYA/stabilizer/conditioner level. That's why you try to add CYA and not backwash for awhile, but sometimes you gotta do what you gotta do. If you have to drain a bit from excess rain, that's what you have to do. Then you retest after the rain stops and adjust accordingly.
    Sandy
    15,600 gallon, screened 15x30 IG plaster sport pool with 6x8 tanning area, Aquarite SWCG, Hayward cartridge filter, Polaris 280 cleaner
    Just a update..
    After shocking the pool, ( I went by the 53 CYA) and directing the return jet to aerate the pool, it is the clearest it's been in a week.
    Fingers crossed...
    Kerrie
