Results 1 to 4 of 4
Thread: Adding borax
    Default Adding borax
    I became impatient and decided to add some borax to the pool (I broadcasted it in deep end and some in shallow). I have since learned on another site to only add it through the skimmer. What happens if I broadcasted it?
    Kerrie
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: Adding borax
    Nothing, it will just dissolve, it is just easier to put it in the skimmer.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Kimrst is offline Registered+ Thread Analyst Kimrst 0
    Michigan
    Mine went slowly into the water in front of the fountin. I don't think it hurt my Intex frame pool. In front of the fountin with the filter running is where I put everything except the cya and I've added mine this year with 6 pucks. Last year I did the cya in the sock trick. kimrst
    Thanks so much....
    I was afraid my impatience caused me to screw up something..
    Kerrie
