Thread: Bubbles from filter exhaust
    dzialga is offline ** No working email address ** dzialga 0
    Default Bubbles from filter exhaust
    I recently notice small air bubbles from the water flow leaving the filter going back into the pool. Any thoughts or suggestions?
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default Re: Bubbles from filter exhaust
    Quote Originally Posted by dzialga View Post
    Sounds like a suction side leak (sucking in air at a joint or crack between the pool and the pump input). If it were on the side after the pump output (pressure side) you would have a water leak somewhere. This is a guess on my part... any other ideas from folks w/ more experience??? Can you see bubbles in the pump basket while the pump is running?
